SS-V: 1100 Raasch Challenge
Test No. VS11Find the tip displacement at the free end of a thick, doubly curved beam.
Definition
The load is a uniform load 1.0 lbf out of plane.
The units are IPS.
The material properties are:
Properties
Value
Modulus of Elasticity
3300 psi
Poisson's Ratio
0.3
Results
The following table summarizes the tip displacement results [in].
  Theory SimSolid % Difference
Tip displacement 4.9355E+00 4.9310E+00 -0.09%
1 F.T. Wong, Testing of Shell Elements using Challenging Benchmark Problems.
